changeing valve cover gasket
Old Apr 20, 2008 | 09:51 PM
boomer8883's Avatar
Default changeing valve cover gasket
99 GST and the valve cover gasket is leaking. is this an easy job? what all do i have to remove to get the cover off?
Old Apr 21, 2008 | 02:33 PM
darknigh7th's Avatar
Default RE: changeing valve cover gasket
there are bolts around the valve cover, just remove them it's an easy fix, just remember when you are putting it back in, not to overtorque the bolts, which is why i'm leaking oil.
Old Apr 21, 2008 | 02:44 PM
dsm1990gsx's Avatar
Also make sure the car is not warm b/c you could strip out the threads, very simple job to do.
Old Apr 21, 2008 | 03:45 PM
yes totally forgot about that, which is pretty important lol.
Old Apr 21, 2008 | 04:27 PM
Kaede.Noir's Avatar
Strip out the threads? explaiin pl0x
Old Apr 21, 2008 | 05:32 PM
dsm1990gsx's Avatar
ORIGINAL: Kaede.Noir
The head is aluminum and w/ its warm its easier to pull the threads out w/ the bolt. Thats why you change your plugs w/ the engine cold.
Old Apr 21, 2008 | 07:22 PM
Kaede.Noir's Avatar
OHHH that makes perfect sense.... didnt think about that.... thnx, do you recommend sillicone or liquid gasket on it? or the gasket is more than enough?
Old Apr 21, 2008 | 07:24 PM
dsm1990gsx's Avatar
The gasket should be more then enough, just make sure the gasket surface is clean and not nicked.
Old Apr 21, 2008 | 07:27 PM
Kaede.Noir's Avatar
Im asking cuz im actually planning on do this as well... i think that gasket hasnt been changed in forver... plus its leaking somewhere... problem is the 420a has this funny lil half moon thing on it that makes it harder o_O
Old Apr 21, 2008 | 08:26 PM
well i wasn't paying attention to the bolts and kept torquing, all of a sudden a little snap, then the wrench kept turning..... ****.[/align]
