-   Everything else (https://mitsubishiforum.com/forum/everything-else-37/)
-   -   Clicking Noise (https://mitsubishiforum.com/forum/everything-else-37/clicking-noise-23140/)
billhamers Oct 30, 2007 06:24 PM
Clicking Noise
Clinking noise when you set the air conditioner at the low level with or without the fan on.
Sebba Oct 30, 2007 07:17 PM
RE: Clicking Noise
What car?
dsm1990gsx Oct 30, 2007 09:09 PM
RE: Clicking Noise
A/c low on charge and compressor cycling fast???
billhamers Oct 30, 2007 10:04 PM
RE: Clicking Noise
2003 Galant
dsm1990gsx Oct 31, 2007 06:31 AM
RE: Clicking Noise
ORIGINAL: billhamers
2003 Galant
You gotta give more info?What engine, where is the noise coming from, ect...
billhamers Oct 31, 2007 08:23 AM
RE: Clicking Noise
Engine model is 4G64. The clicking sound can only be heard inside the car. I did lift up the hood and heard no noise. It is only present when the air conditioning mode is at the lowest level. When you move the dial up to the second blue line the clicking stops. Any ideas as to what the problem is?
billhamers Oct 31, 2007 09:17 AM
RE: Clicking Noise
A new twist to my problem. The clicking noise is present when the tempature control is at one of the two lowest levels and it does not matter if the air is on or off . If you move the tempature dial past the two lowest setting the noise stops.
dsm1990gsx Oct 31, 2007 02:27 PM
RE: Clicking Noise
You proably have a bad blend door motor. Do all of your ac/heater contols work normal?
billhamers Oct 31, 2007 08:55 PM
RE: Clicking Noise
All controls work as they should with the exception of the low air setting when the clicking happens. If it is the blend door motor is this something that the average person can fix?
If so where is the motor located? Do you have to take the dash apart to fix? Any sugestions on fixing is appreciated.
Bill
dsm1990gsx Nov 1, 2007 01:13 PM
RE: Clicking Noise
Bill
Its different on all cars, sometimes you can get to itunder the dash and other times you gotta pull the dash to get to it. Kinda hard to say.
