Clutch slipping Issues
O k I know i asked already but i need more help with this issue. I replaced the clutch, pressure plate,and throw out bearing. well now the clutch slips under hard accelaration in almost all gears. Someone told me that it was not properly adjusted after the installation was completed something that is necessary on these hydraulic units.
So my question or questions are how Do I ADjust the clutch? Also like i posted last time my pedal is too soft its not that it stays stuck when i press it but there is no resistence its worst than a stock feel to it. and Finally should my clutch pedal stay stuck to the floor after i bleed it, or should it pop back UP? because I end up have to pull mine up by hand.
KB1Alpha
Aug 28, 2014 07:56 AM
