code P0302
Ok I know the code means misfire on cylinder 2. Now does anyone know what I have to do to fix the problem. I switched the spark plugs and wires obout 5k miles ago. That fix the problem for awhile, and now its back again.
code P0302
Clean the injectors replace the plugs with NGK ...you will be happy with the results ....of course make sure you clear the code
code P0302
thanks I'll try that and tell you if it works</P> </P> |
code P0302
I have good faith in this one
