code P0302
Old May 13, 2004 | 01:50 PM
quinny's Avatar
Default code P0302
Ok I know the code means misfire on cylinder 2. Now does anyone know what I have to do to fix the problem. I switched the spark plugs and wires obout 5k miles ago. That fix the problem for awhile, and now its back again.
Old May 13, 2004 | 04:11 PM
Mitsu-Tech's Avatar
Default code P0302
Clean the injectors replace the plugs with NGK ...you will be happy with the results ....of course make sure you clear the code
Old May 13, 2004 | 05:54 PM
quinny's Avatar
Default code P0302
thanks I'll try that and tell you if it works</P>
</P>
Old May 13, 2004 | 06:36 PM
Mitsu-Tech's Avatar
Default code P0302
I have good faith in this one
skoot61
Dec 4, 2010 12:30 AM
Steve23147
Dec 3, 2010 11:57 PM
hank1996
Oct 23, 2010 02:16 PM
onelovedao
Nov 8, 2009 01:47 PM
Schmyggy
Jul 7, 2004 12:04 PM
