Computer swap?
Old Apr 10, 2006 | 05:47 AM
mattt's Avatar
Default Computer swap?
i got a 96 mitsubishi rvr with 4g63 motor, and i picked up two evo computers.
They plug strait in and 1 Just turns over and the other Trys To fire, iv also tryd runing evo air flow meter but doesnt help.
What do i need to do to run a evo computer??
Old Apr 10, 2006 | 09:58 AM
Default RE: Computer swap?
what exactly are you doing. Taking the stock harness off the ecu and plugging it into the evo one?
Old Apr 10, 2006 | 10:26 AM
slow420a's Avatar
each car has different needs that the ecu does, For example the 97-99 dodge neon r/t shares the 420a motor with the 95-99 eclipse. Many aftermarket companys make "chips" for the neon but only one does for the eclipse(97's only). Even though their the same motors their are slight differences that wont let the ecu's work.
Old Apr 10, 2006 | 05:55 PM
mattt's Avatar
yep , just unplugging the 3 plugs that go into starndard ecu and pluggin them into the evo 1
Old Apr 10, 2006 | 06:13 PM
willdue's Avatar
why would u switch ecus?
Old Apr 10, 2006 | 07:19 PM
I am not sure it will run properly if at all...but i dont know
rstoevo
Jan 20, 2013 10:47 AM
balbatron
Dec 1, 2005 12:04 AM
Drykan
May 25, 2004 02:55 AM
glockman
May 21, 2004 01:34 AM
glockman
May 18, 2004 11:01 PM
