Early evo 123 shape lancer questions
hi guys
im from new zealand. i have a fwd lancer (same shape as evo 1 2 and 3). It is auto with F4a21 transmission and 4g91 efi engine. i have bought pedal box, flywheel shifter etc to convert to manual, i plan to use the 1.6 f5m22 gearbox. i am also wanting to build a strong n/a engine over the next few months and i have some quiries If i were to use a 4g93 turbo short block, 4g93 head, 4g92 cams with adjustable gears, 4g93 n/a exhaust manifold as its 4-2-1, with 4g93 intake plenum, evo injectors, 60-70mm throttle body, cold air intake which ecu would I need? i couldnt run all this off the 4g91 ecu could I? would i be able to use 4g91 ecu if i used a 4g91 block with 4g93t head, intake t/body and evo 1 injectors?? would the evo injectors be too large? any help would be awesome im not sure which way i can go without messing with loom changes etc thankss |
