Early evo 123 shape lancer questions
Old Mar 26, 2011 | 06:24 PM
madnamitz's Avatar
Default Early evo 123 shape lancer questions
hi guys
im from new zealand. i have a fwd lancer (same shape as evo 1 2 and 3). It is auto with F4a21 transmission and 4g91 efi engine.
i have bought pedal box, flywheel shifter etc to convert to manual, i plan to use the 1.6 f5m22 gearbox.
i am also wanting to build a strong n/a engine over the next few months and i have some quiries
If i were to use a 4g93 turbo short block, 4g93 head, 4g92 cams with adjustable gears, 4g93 n/a exhaust manifold as its 4-2-1, with 4g93 intake plenum, evo injectors, 60-70mm throttle body, cold air intake
which ecu would I need? i couldnt run all this off the 4g91 ecu could I?
would i be able to use 4g91 ecu if i used a 4g91 block with 4g93t head, intake t/body and evo 1 injectors??
would the evo injectors be too large?
any help would be awesome im not sure which way i can go without messing with loom changes etc
thankss
Qamar
May 12, 2008 03:02 PM
estraw
Aug 17, 2007 04:17 PM
Brillo
Apr 26, 2007 08:06 PM
smokingwheels
May 20, 2006 10:52 AM
suga
Aug 9, 2005 12:10 PM
