Eclipse suspension
Old Jan 11, 2005 | 01:33 PM
mrgordijev's Avatar
Default Eclipse suspension
Hey guys,
Theres a little bit of a problem with my car. There is squeaking coming from either the suspension or the shocks on my car. I am kind of a newb when it comes to the technical aspect of cars so bear with me. I would like to know how much you guys think it will cost to fix this. THanks for your time.
-Mike
Old Jan 11, 2005 | 07:31 PM
96awd's Avatar
Default RE: Eclipse suspension
how many miles on it. might just be that you need new struts, if you want stock stuff just go to a local parts place and find out what new struts will be.
Old Jan 11, 2005 | 08:38 PM
mrgordijev's Avatar
I got 69,213 miles on it right now. You think it could just be the struts? Thanks for your input.
Old Jan 23, 2005 | 10:21 PM
mrgordijev's Avatar
Alright, I replaced the struts, and the mechanic lubed up the bushing, and IT STILL MAKES THIS NOISE!! My friends friend, lol, says that it could be my suspension since it lowered 2 inches. Did anyone else have this problem?? Its hecka annoying hearing that damn noise. Please POST. Thank you.
-Mike
Old Jan 24, 2005 | 05:41 AM
1398spdr's Avatar
ok, what size rims are on it
do you have a cam kit
what kinda springs are on it
you just got new struts, correct
could be the springs are bad
Old Jan 24, 2005 | 05:49 AM
mrgordijev's Avatar
Ok I have stock eclipse rims and no I dont have a cam kit. I have ground control springs, if I replace them , wut do you reccommend I get? eibach or somethin?
Old Feb 4, 2005 | 02:07 AM
baker_sk8er37's Avatar
when lowering your car that much (2 inches) you need to get a camber kit without it yor going to get premature wear of suspension components which may result in your springs going bad so that may be the problem
i say go with eibach if you want to they are a good company but make sure its your shocks that are bad first!!!!!
Old Feb 5, 2005 | 05:58 AM
DSMTalonAWD51's Avatar
you have aftermarket springs, just because they make noise doesnt necessarily mean anything is wrong with them. my friends integra squeaks really bad an all of his suspension work is brand new, some stuff just does that. if it bothers you that much you could sell them an try eibach. i ahve the pro kit an they dont make any noise. As for shocks with any aftermarket springs you really should consider investing in a quality shock, they makie a world of a differnece and any aftermarket springs will wear your stock shocks in no time they are weak.
Cushman
1st Generation
Nov 18, 2010 10:47 AM
Kostya P
Sep 28, 2009 10:21 AM
eclipse99
May 29, 2006 11:44 PM
ictponder
Apr 23, 2006 04:04 PM
diki9111
Dec 8, 2005 07:23 PM
