Electrical - OEM Wiring Harness for 07 Outlander
Old Nov 14, 2007 | 04:14 PM
islandrider's Avatar
Default Electrical - OEM Wiring Harness for 07 Outlander
Has anyone installed/had installed the Mitsubishi harness for the 2007 Outlander?
I had mine installed, and it is not working. Used my buddy's volt meter on it, and it showed 0.2 Volts instead of @12 or so. This would explain why it isn't working...
I checked the ground and the installation, and it appears to me that it may be the so-called 'converter module' which isn't converting the LED voltage up to the trailer voltage.
Has anyone else encountered this problem on this or any other vehicle?
I suspect it may be a defective part, just like to know if I am alone on this.
Cheers,
Paul
Old Nov 23, 2007 | 04:00 PM
smokinu6's Avatar
Default RE: Electrical - OEM Wiring Harness for 07 Outlander
check for body grounds back probe the ecm for your 0.5vlt referance singals and ecm grounds if all good bad part.
Old Dec 10, 2007 | 11:36 AM
it was a bad part indeed, but the dealer just reconfigured it by re-arranging the wiring within the harness, and now it all appears to work. thanks for the input!
islandrider
Aug 11, 2020 06:07 AM
JxStaalx11
Jun 26, 2011 05:03 PM
AllThingsDSM
Feb 8, 2006 01:33 PM
denied
Feb 9, 2005 12:16 AM
