I need some Help Plz.
Old Dec 10, 2007 | 05:53 PM
zeox100003's Avatar
Default I need some Help Plz.
Hi!
I have a 1998 Eclispe, and when I changed the battery, the anit-theft mechanism in my radio engaged.
I bought the car from someone else, I don't have the manual.
Does anyone have a stock code, or default code that I can try, Will that even work?
Any Help is appreciated.
I need MuSiC :P
Old Dec 10, 2007 | 06:05 PM
Default RE: I need some Help Plz.
Not sure if this will work, but leave the key in the ignition for an hour with the radio on(i know). I did this with a couple others, and it worked.
Old Dec 10, 2007 | 06:47 PM
jason clipse's Avatar
stealership might be able to help u
Old Dec 11, 2007 | 11:56 AM
you have to go to the dealership. You need your VIN# and if you can get to the radio unit on the top of it has a serial code. I believe you need both to get your code from them
Old Dec 11, 2007 | 12:26 PM
shreff99's Avatar
I think you have to pull the radio out and the code should be stamped on it somewhere...But when you yank it out just put in a nice Pioneer or other decent head unit instead of the factory one and you won't have to worry about the code.
Old Dec 12, 2007 | 06:54 AM
nah the code isnt on it. Its just the serial number which you give to the dealership
Old Dec 13, 2007 | 01:45 AM
4g63419's Avatar
Does it display read "Call 800", then try 1800-233-2216 for assistance
10outlander
Feb 16, 2012 07:28 PM
SERPENTOR
Jan 8, 2012 09:38 AM
Syrian24
Dec 16, 2008 07:22 PM
atown420
Oct 1, 2007 02:32 PM
cresston
Sep 25, 2006 12:26 AM
