engine problems
my 94 eclipse gs 2.0 n/t misses under low load, no matter what gear ts in or how many rpms. jus when i barely touch the gas pedal to maintain a constant cruising speed the engine misses. i have already done plugs, wires, coil,fuel filter and air filter. any help would be greatly appreciated. thank you in advance
RE: engine problems
Sorry to say that it sounds like a cam or valve problem. Take the valve cover off and check to make sure nothing has broken. Check the clearance on all valves. If you don't find something there, it might be the valve itself.
RE: engine problems
Sounds like your timing is off
