engine problems
Old Aug 9, 2006 | 04:45 PM
DaClipsa's Avatar
Default engine problems
my 94 eclipse gs 2.0 n/t misses under low load, no matter what gear ts in or how many rpms. jus when i barely touch the gas pedal to maintain a constant cruising speed the engine misses. i have already done plugs, wires, coil,fuel filter and air filter. any help would be greatly appreciated. thank you in advance
Old Aug 9, 2006 | 06:50 PM
VR4GARY's Avatar
Default RE: engine problems
Sorry to say that it sounds like a cam or valve problem. Take the valve cover off and check to make sure nothing has broken. Check the clearance on all valves. If you don't find something there, it might be the valve itself.
Old Aug 9, 2006 | 07:11 PM
Sounds like your timing is off
99Silvergs
Feb 25, 2017 09:03 AM
jp2000
Jan 1, 2012 05:21 PM
p4c0
Feb 22, 2007 06:36 PM
shamsulaswad
Oct 31, 2004 07:44 PM
Ooopsy67
Jun 30, 2004 10:16 AM
