Engine Probs
I have a 91 eagle talon turbo car it was running fine and now the engine is missing and wants to die when you push on the gas... I dont know what it is.
RE: Engine Probs
have you done a tune up on it? changed fuel filter plus and wires. also check the timing on it.
RE: Engine Probs
ORIGINAL: 99clipsgst have you done a tune up on it? changed fuel filter plus and wires. also check the timing on it. Another question... My headlights, dome lights and, brake lights only work when the car is on. Is this year supposed to do that or is it wiring? It had a security system in it and i ripped it out but, it still does the same thing as when it was in... |
RE: Engine Probs
I found out the whole problem to it all... It was a 80amp fuse going to the alternator!
causing all this problem! |
RE: Engine Probs
The 1st gen Talon's don't have a voltage guage. This is the simplest thing to install.
DT |
RE: Engine Probs
ORIGINAL: Dans Talon The 1st gen Talon's don't have a voltage guage. This is the simplest thing to install. DT |
RE: Engine Probs
it is probably the alternator mine did the same thing when the alternator went out
