Engine Probs
Old Feb 28, 2005 | 08:28 PM
DragonRacerX666's Avatar
Default Engine Probs
I have a 91 eagle talon turbo car it was running fine and now the engine is missing and wants to die when you push on the gas... I dont know what it is.
Old Mar 1, 2005 | 12:48 AM
99clipsgst's Avatar
Default RE: Engine Probs
have you done a tune up on it? changed fuel filter plus and wires. also check the timing on it.
Old Mar 1, 2005 | 01:52 AM
ORIGINAL: 99clipsgst
No but, I dont see why it would do that after running fine for a week but!! I took a wire off my sensor on the throttle and it stopped doing it sorta and plus my battery kept going dead so i think it may be the batter and or alternator.
Another question... My headlights, dome lights and, brake lights only work when the car is on. Is this year supposed to do that or is it wiring? It had a security system in it and i ripped it out but, it still does the same thing as when it was in...
Old Mar 2, 2005 | 01:11 AM
I found out the whole problem to it all... It was a 80amp fuse going to the alternator!
causing all this problem!
Old Mar 2, 2005 | 09:45 AM
Dans Talon's Avatar
The 1st gen Talon's don't have a voltage guage. This is the simplest thing to install.
DT
Old Mar 3, 2005 | 02:29 PM
ORIGINAL: Dans Talon
DT
I never said anything about a voltage guage.
Old Mar 20, 2005 | 07:19 PM
gsx man's Avatar
it is probably the alternator mine did the same thing when the alternator went out
kUNFUSION209
Aug 19, 2006 11:49 PM
kylewatkins
Apr 19, 2004 11:48 AM
T76 turbo
Apr 16, 2004 04:53 PM
T76 turbo
Apr 15, 2004 01:02 AM
trooper18233
Oct 26, 2003 01:07 AM
