engine stalls when put in drive or reverse
Old Mar 23, 2006 | 12:10 PM
backyardmech's Avatar
Default engine stalls when put in drive or reverse
I have a 94 eclipse that runs good in park or neutral, but when I put it in drive or reverse the engine ( 1.8) stalls.When the car is coasting and then put in drive it stays running and goes thru all the gears untill I stop and it stalls. I replaced the torque converter, but it didn't help. If anyone has some ideas I would really appreciate your input. Thank you in advance.
Old Mar 23, 2006 | 03:11 PM
Sanguinius's Avatar
Default RE: engine stalls when put in drive or reverse
How's the idle when it's in nuetral? Is it low or does it sit at 700-800RPM when warm?
Old Mar 23, 2006 | 04:55 PM
It sits @ 1100. I changed the two sensors, but it didn't help. It was doing fine untill I stopped to get gas and that was when it stalled.
Old Mar 28, 2006 | 06:06 PM
mitsu5002's Avatar
check if the idle speed control motor is starting to get lazy or it can be a possible ecu problem. Might need to go to dealer with that.
loudmtx05
Nov 6, 2017 07:53 PM
backyardmech
Jan 23, 2016 11:44 AM
K Minton
Jan 5, 2015 10:43 PM
sponky
Jun 9, 2014 01:38 PM
backyardmech
Mar 30, 2006 02:27 PM
