Engine Swap
Ok i have a 97 Mirage LS 4dr. was wondering if either one would fit in a mirage and also how much esxtra money it would be for all the supporting parts. Also if you have an idea of which would be the better choice that'd be nice to.
Eclipse 4G63T 89-94 2.0L DOHC TURBO - Engine, 5-Speed AWD Transmission Lancer Evolution 4G63T 90-94 - Engine, MT AWD Transmission |
RE: Engine Swap
Engine mounts, accessory mounts,bellhousing bolt pattern,and all interface points are identical on all these engines. The only thing you need to be concerned with when going from the normally aspirated engine in your car to the Turbo is that you will need to use the ECM and all engine sensors from the Turbo car. Good luck with the swap!
RE: Engine Swap
thanks man. i was talking to my bro who knows a lot more than me and he thinking i should just turbo the mirage engine and get almost the same hp
RE: Engine Swap
If your Mirage has the 2-liter engine in it already, it's the same engine as the twin-cam turbo except for the SOHC cylinder head (engine code 4G63 for the SOHC 2-liter). This engine should perform very well with a turbo, and would run very close to the twin cam.
However, if you have the 1.8 liter single-cam, I doubt that it would live up to the performance potential of the 2-liter twin cam turbo, no matter how much boost you tried shoving through it. No substitute for cubes... |
RE: Engine Swap
4g63(t) always have DOHC, I thought? Are u sure about this?
