Engine Swap
Old Jul 6, 2007 | 12:18 PM
pntballakev's Avatar
Default Engine Swap
Ok i have a 97 Mirage LS 4dr. was wondering if either one would fit in a mirage and also how much esxtra money it would be for all the supporting parts. Also if you have an idea of which would be the better choice that'd be nice to.
Eclipse 4G63T 89-94 2.0L DOHC TURBO - Engine, 5-Speed AWD Transmission
Lancer Evolution 4G63T 90-94 - Engine, MT AWD Transmission
Old Jul 6, 2007 | 01:32 PM
lars's Avatar
Default RE: Engine Swap
Engine mounts, accessory mounts,bellhousing bolt pattern,and all interface points are identical on all these engines. The only thing you need to be concerned with when going from the normally aspirated engine in your car to the Turbo is that you will need to use the ECM and all engine sensors from the Turbo car. Good luck with the swap!
Old Jul 6, 2007 | 02:24 PM
thanks man. i was talking to my bro who knows a lot more than me and he thinking i should just turbo the mirage engine and get almost the same hp
Old Jul 6, 2007 | 02:54 PM
lars's Avatar
If your Mirage has the 2-liter engine in it already, it's the same engine as the twin-cam turbo except for the SOHC cylinder head (engine code 4G63 for the SOHC 2-liter). This engine should perform very well with a turbo, and would run very close to the twin cam.
However, if you have the 1.8 liter single-cam, I doubt that it would live up to the performance potential of the 2-liter twin cam turbo, no matter how much boost you tried shoving through it. No substitute for cubes...
Old Jul 6, 2007 | 08:02 PM
Dusty Eclipse's Avatar
4g63(t) always have DOHC, I thought? Are u sure about this?
rstoevo
Jan 20, 2013 10:47 AM
kiwii29
Jul 31, 2009 01:18 AM
greg999
Dec 1, 2003 10:49 PM
mekka
Oct 17, 2003 07:51 PM
tristanlee85
Jul 2, 2003 01:29 AM
