Evo 1-3 Engine Block
Old Oct 30, 2005 | 05:59 AM
bedbod's Avatar
Default Evo 1-3 Engine Block
Hi,
I was after getting some pics of the evo block to see if mitsubishi deleted the RWD castings off the evo spec block.
I know that VR4 engines still have the side mounts on them.
I have a rear mounted 4G63 single cam carby engine and i have seen the VR4 engines mounted the same way. I am picking up an EVO 3 engine in a few days and i hope it will sit on the same mounts without too much worry. I realise that the turbo will be facing the wrong way, and the thermostat outlets are at the rear of the engine.
Second thing is that i heard a rumour that only the EVO4 and later cranks are 7 bolt and all the others are 6. I always thought all the EVO's were 7 bolt.
thanks in advance
clips69
Mar 5, 2008 06:49 AM
dorian7
Jan 22, 2008 06:09 PM
cosmicrain813
Aug 13, 2007 04:47 PM
leg1lcs
Nov 20, 2006 04:19 PM
ttenn
Jun 10, 2006 01:45 AM
