Fuel injectors and timing belt replacement
Old Dec 28, 2004 | 09:13 PM
osu girl's Avatar
Default Fuel injectors and timing belt replacement
Does anyone know about replacing fuel injectors in an eclipse? I think mine need replacing and I wonder if I need to take this to a shop or if it's something that can be done in the garage at home. I'm having hesitation and choking up to 2500 rpms about 90% of the time and it's getting worse. The only thing that fixes my problem is fuel injector cleaner but I want to fix the problem for good. Any suggestions?
Also, does anyone know when the 99 eclipse is supposed to have the timing belt changed? I've heard 60k and 100k.
Old Dec 29, 2004 | 12:00 AM
96awd's Avatar
Default RE: Fuel injectors and timing belt replacement
timming belt should be done every 50,000 to 60,000 miles. is your car turbo or n/a. i would change the fuel filter for sure.but i would check to make sure that the injectors were the problem before changing them. and yea they can be done at home they just plug in,you just have to take the fuel rail off 3 bolts i think then they just plug in.
Old Dec 29, 2004 | 12:43 AM
midnght's Avatar
60k I would do the belts and a STOCK water pump kit only if the pullies are not leaking anywhere.
120k replace all pullies, water pump kit again, and belts
If it is a Nonturbo change those to 100k and 160k.
This is what I do and have done for years. Never had a problem.
As for your other problem, after you answer 96awd the answer will be put up.
Old Dec 29, 2004 | 08:23 PM
osu girl's Avatar
My eclipse is non turbo, it has 62k on it. I've replaced the serpentine belt, spark plugs and wires, the front o2 sensor, front wheel hub (drivers side), and oil changes every 3-4k miles. Where is the fuel filter on this car?...Thanks.
Old Dec 29, 2004 | 11:07 PM
midnght's Avatar
Here let's get it all out of the way.
Year
Make
Model
Engine
Since there are 6 or so different types of variations and/or codes this will help.
Old Jan 2, 2005 | 01:34 AM
osu girl's Avatar
'99 Mitsubishi Eclipse GS 2.0 4cyl 5 speed
Old Jan 2, 2005 | 12:46 PM
96awd's Avatar
i think that on the 96-99 n/t they are mounted to the fuel tank.on top were the access panel to the fuel pump is.
Old Jan 3, 2005 | 12:04 PM
osu girl's Avatar
Thanks for the help
Old Jan 3, 2005 | 03:22 PM
96awd's Avatar
no prob.
Old Jan 5, 2005 | 08:54 PM
vertstanggt's Avatar
I should do that to mine too, havn't gotten around to it yet since I've been at school and no place to work on it. Where's the access panel?
