FUEL PRESSURE REGULATOR
There are a couple ways to hook one up. I believe there is one that bolts right on to the end of the fuel rail, makes it very EASY. For the advanced setup you get some 8AN and 6AN O-Ring style fittings and steel braided fuel lines. Then you place the FPR some where on the return line from the fuel rail. You replace the whole return line with the steel braided line, atleast the rubber part. Most of the FPR have guage taps WHICH YOU WILL NEED. Then from there you just research and find out what Ideal fuel pressure is.
Quick93gsx
09-16-2007 07:01 PM
Quick93gsx
1st Generation
09-16-2007 07:01 PM
