FUEL PRESSURE REGULATOR
Old Jan 24, 2006 | 11:32 PM
player69x's Avatar
Default FUEL PRESSURE REGULATOR
How do i install a Fuel pressure regulator? and how do you adjust it so it pushing more fuel.
Old Jan 25, 2006 | 01:20 PM
NESpeed's Avatar
Default RE: FUEL PRESSURE REGULATOR
There are a couple ways to hook one up. I believe there is one that bolts right on to the end of the fuel rail, makes it very EASY. For the advanced setup you get some 8AN and 6AN O-Ring style fittings and steel braided fuel lines. Then you place the FPR some where on the return line from the fuel rail. You replace the whole return line with the steel braided line, atleast the rubber part. Most of the FPR have guage taps WHICH YOU WILL NEED. Then from there you just research and find out what Ideal fuel pressure is.
rockraul07
Feb 28, 2009 01:45 PM
Quick93gsx
Sep 16, 2007 07:01 PM
Quick93gsx
1st Generation
wicked_outlander
Feb 19, 2006 10:55 PM
Frost
Mar 6, 2005 04:28 PM
