Gauges
My gauges are done, got all three in my car within one day, up and working and no oil leaking for my oil pressure gauge. i'm getting good oil pressure and i'm boosting at 10 psi in first and holding, and 14 psi in 2,3,4,5 and holding, and i don't have a boost controller and i'm boosting at 14, is that good? i don't know what the person who had it before me did to it.
RE: Gauges
no 14 psi is too high to be stock. So its either the guage is reading wrong, or you actually have a boost controller. is it a mechanical guage?
RE: Gauges
http://cgi.ebay.com/2-1-16-TINTED-TU...QQcmdZViewItem
this is the ebay store i got it at, glowshift, it's a mechanical gauge. |
RE: Gauges
something must be messed up cuz stock shouldnt be doing that. Even if the restrictor was removed it wouldnt run that high.
RE: Gauges
i'll check over everything tonight and see if anything is out of place or messed up.
RE: Gauges
Hmmm, I'm not sure (I'll check on it in a sec), but isn't stock boost for the 2g 12psi-13psi? If so, I would say that the restrictor on the solenoid was removed because that would give back 1psi-2psi.
Just checked, 12psi-14psi is ok for 2G, although, that's high in the sense that the stock bov will leak itself back down to 11-ish psi, lol. If you really are solid at 14psi, you've lucked out and you have a freak 2g bov, lol. |
RE: Gauges
well i think stock psi on a 2g is acually supposed to be around 9-10psi and with the restrictor removed you get about 12psi. So that is why i was saying i think that 14 psi stock is kinda high.
RE: Gauges
after all the emphisis on ebay **** why the hell to people still do it?
RE: Gauges
ORIGINAL: silvercoupe97 Hmmm, I'm not sure (I'll check on it in a sec), but isn't stock boost for the 2g 12psi-13psi? If so, I would say that the restrictor on the solenoid was removed because that would give back 1psi-2psi. Just checked, 12psi-14psi is ok for 2G, although, that's high in the sense that the stock bov will leak itself back down to 11-ish psi, lol. If you really are solid at 14psi, you've lucked out and you have a freak 2g bov, lol. |
RE: Gauges
all that would do is make it hold boost better. It wont make the car run higher boost than normal. But the way id look at it right now. If you really are running 14psi. Then therre isnt really isnt much to worry about since the car can handle 16psi on stock fuel. So nothing is gonna happen to your car.
