Help random leak! in 420a eclipse 1998 engine
Old May 18, 2007 | 12:07 PM
darkbannanna's Avatar
Default a
abcdef
Old May 18, 2007 | 12:12 PM
Dusty Eclipse's Avatar
Default RE: Help random leak! in 420a eclipse 1998 engine
Well, the pics arent showing up here very well... but what makes you think thats brake fluid??
Old May 18, 2007 | 12:22 PM
Not sure The liquid is kind of yellow ish and thick, mabey oil?
I checked oil level and its 1/2 way between min and max so im not sure if its oil thats leaking, if it is oil its not leaking a ton
Old May 18, 2007 | 12:25 PM
No its not oil. Dont worry. If you can get a better picture from more of a birds eye view it would be helpful.
Old May 18, 2007 | 12:35 PM
I got better pix ill post em in a sec the fluid seems to leak when im revving my engine in the rpm range of 5-7 and mabey a litle at 4. Color is a yellowish brownish (note i just got full synthetic oil placed in my car last week, I am pretty sure its just a loose hose and i can fix it myself but i need to know what the fluid is.
Old May 18, 2007 | 01:52 PM
OK I definatley foudn out its powersteering fluid thats leaking and i got it setup to get fixed later but i need to know will power steering fluid **** up my paint? Ive heard stories that it might screw up paint jobs if it gets on cars
Old May 18, 2007 | 02:05 PM
It very well could **** up your paint... good call on the pwr steering fluid though, I ws thinking thats what it was...
Old May 18, 2007 | 03:15 PM
It WILL NOT mess up paint
Old May 18, 2007 | 09:02 PM
I Drive Naked's Avatar
I'm not trying to be a dick, but sence your leak was under the power steering resevoir, why did you not suspect that first?
Don't panic, its probally just a line being where its at.
The resevoir is metal and wont leak unless punctured.
guyjg
Nov 13, 2021 03:27 PM
TheRock0720
Nov 12, 2010 12:30 PM
lillben07
1st Generation
Jun 4, 2009 11:22 AM
halfasss101
Sep 4, 2007 02:35 PM
svnlogin
Apr 15, 2006 06:03 PM
