L200 Animal 2005 won't rev up
Old Apr 7, 2021 | 05:12 AM
helialex's Avatar
Default L200 Animal 2005 won't rev up
HI all,
I own an L200 2005 animal K74 that has developed a fault, to start with on cold days when started the EML would come on after starting and the engine would not rev until it was warm. This has got progressively worse to the point it is not not useable. Currently when started it will rev up for 2/3 seconds then the EML will come on and it won't rev up . Code wise it has shown 12 / 18 pump speed and turbo over boost. The turbo waste gate was not moving well so after checking lose wires/ split pipes I had the Turbo removed and reconditioned and it has not solved the issue, I have swapped the EGR valve no change , checked the timing , checked the cat in the exhaust has not collapsed. Swapped sensors with my mates truck etc Kind of running out of ideas! anybody got a clue ... will certainly make it worthwhile for anyone providing the solution ......
Thanks Alex
Animalmit
Mar 20, 2019 04:33 PM
kalf
Apr 24, 2016 07:09 AM
scoobyking123
Oct 30, 2011 03:27 PM
scoobyking123
Oct 30, 2011 03:26 PM
hotponyshoes
Jul 4, 2010 05:43 PM
