LED wiring
Old Sep 7, 2005 | 09:18 PM
Alexgor56's Avatar
Default LED wiring
I just bought a shift **** with an LED light in it. However, I am having trouble finding where to attach the wires. The directions say: "Connect the black wire to a chassis ground, connect the gray wire to the dash board light power wire (wire is accessible from either the fuse box or dimmer switch). Can someone find these for me? I drive a 2003 Eclipse GS. THANKS!
Old Sep 8, 2005 | 10:51 AM
newEclipse's Avatar
Default RE: LED wiring
the Fuse box is on the far left of the Dash on the driver side. It is in a little compartment that you cant see unless you open the door.
The dimmer wires are easy to get to as well. just take you HUD and pull it up dont worry you wont break it. but the wires you see are where the dimmer goes to the HUD. the accual dimmer wire you can see from the side compartment where the fuse box is.
Hope this helps
theiss2200
Sep 12, 2019 08:07 PM
djet38
Oct 2, 2013 08:17 AM
Tyler Zettl
Jan 17, 2012 10:40 PM
TVP
Apr 28, 2005 12:34 PM
