Loss of power
Old Aug 30, 2005 | 09:24 AM
newEclipse's Avatar
Default Loss of power
Just recently i have noticed an almost complete loss of low end torque. It just happened two weeks ago. I dont know why it happend, but it was really sudden and i dont think there is a major problem but i would like some suggestions on what it could be.
Things to think about
- Just changed oil -Q advanced
- bad tires
- have been using gas from the same station for the last two weeks. - Amoco Ultimate
- I have used fuel injector cleaner.
Old Aug 31, 2005 | 03:12 PM
305RS97's Avatar
Default RE: Loss of power
What octane have you been putting in the car? Not only do i have an RS but an integra and when i put low octane fuel in it i notice a power diffrence. Maybe check your Spark Plugs, might not be firing the right way.
Old Aug 31, 2005 | 03:20 PM
Patrick's Avatar
Administrator
bad tires wont cause a loss of power...how many miles are on your car? any CEL?
have you checked the oil?
what engine..trans?
Old Sep 1, 2005 | 09:11 AM
newEclipse's Avatar
Yes i have checked the oil, and have already said that.
the gas was premium. I always put premium in the car becase is says to. but the spark plugs are worth looking into if i could only find the other three.
Old Sep 1, 2005 | 11:35 AM
Patrick's Avatar
Administrator
honestly, the "back" spark plugs are a NIGHTMARE to get to..you have to practically take the top of the engine apart...thats why most places will charge a Ton for a tune up...
the plugs are under the intake manifold...
has the car overheated at all recently??
Old Sep 1, 2005 | 12:35 PM
305RS97's Avatar
if ya can get to them try and check your plugs and wires.
Old Sep 1, 2005 | 04:04 PM
Patrick's Avatar
Administrator
a bad plug or wire, or any misfire issue, will trigger a CEL...i had a cracked plug that WAS firing, so i felt no difference, but i still had a CEL
Old Sep 6, 2005 | 10:53 AM
newEclipse's Avatar
Thanks yall, that is really good info to know. but i Think the Problem was just the gas. It is working better now. But I have another question.
Unfortunatlly i have an automatic, and when i put it in reverse i hear a short buzz an then a ping that sounds like hitting two metal poles together. Have any idea what that could be?
Old Sep 6, 2005 | 12:55 PM
305RS97's Avatar
does it do this when putting it in drive also? I hear this noise also when putting it into drive and reverse, just without the metal ping at th end? Someone told me it's supposed to sound like that but i doubt that very much.
Old Sep 26, 2005 | 01:14 PM
shreff99's Avatar
Also try changing your fuel filter...it could be clogged.
