Maf sensor normal readings
I just put an injen SRI/CAI on my 2005 Eclipse Spyder GS. I have a OBD-II scanner which reads the engine's sensors while it is running. To see how much more airflow this setup was bringing into the motor over the stock setup I was hoping someone could tell me what the typical g/cm3 readings are. I have checked my Chilton manual and in the emissions section it only tells me what the voltage should be when testing to see if the MAF sensor is working properly. I looked in the 3rd generation forum section and found the service manuals but it didnt give me any information on what the working readings should be. Can anyone help me out here? Thanks.
JNRmonterosport2002
Jun 22, 2008 12:22 PM
