MAGNA TN WAGON FUEL TROUBLES
Old Apr 18, 2005 | 09:44 PM
o0olifeguardo0o's Avatar
Default MAGNA TN WAGON FUEL TROUBLES
Hey Guyz.
My TN Magna seems to have a fuel problem.
I replaced the Carb. as the auto choke was not working and the engine was cutting out on acceleration, with rough idle wwhen cold.
With the new carb. it starts fine, with good idle, but still cuts out after 30 seconds when cold, when warmed up it keeps idle but on acceleration still cuts out again, and again, and again...whenI get to cruising speed of 110kms its ok...but still has that "cut out" feeling.....
I blocked/clamped the secondary fuel hose on the return side from carb, to where is re circulates back to the carb at the back....I did this to raise back pressure to carb and it works great, the question is, is it a fuel blockage, or is the fuel pump on the way out.
Is this a common fault with TN Magnas
Is there an easy/cheap fix here...and if so...WHAT IS IT! :crying:
Thanx in advance.
jajm
Apr 24, 2011 08:25 AM
scone
Jul 3, 2005 10:47 AM
james2b
Mar 29, 2005 08:55 PM
james2b
Mar 29, 2005 06:12 AM
Seth
May 13, 2004 04:55 PM
