MBC HELP!!!
Old Jul 9, 2005 | 03:42 AM
drewblueeye's Avatar
Default MBC HELP!!!
Ok I have a question, if I buy a manual boost controller how does it work? I think I have a good idea but I need to know if I am right. This is my Idea: I have a2005 Evolution 8 and since my boost is 19psi at full throttle and then after so many RPMs it drops to 16 psi, BUT if I install a Manual Boost controller, if I set the MBC to 18 PSI then It will be 19 psi at full throttle and then drop to 18psi, correct? The reason I ask is because I was thinking of setting the MBC to 19psi, so it will be 19 psi all the way to red line. I just want to make sure that if I set it to 19psi that it isn’t going to be like 23 PSI at full throttle and then drop to 19 psi. AM I right though on how it works?
Also Is a MBC worth the money? and if so what brand is the best to use with no issues?
Gstfat
Jul 28, 2007 05:20 PM
get435
Dec 22, 2005 10:59 AM
DixonsGst
Oct 30, 2005 09:47 PM
99clipsgst
15
Aug 25, 2005 04:41 PM
USCordia
Aug 13, 2005 06:41 PM
