MIL Codes 12, 13, 25 - Mass Air Flow sensor?
Old Feb 12, 2013 | 09:28 PM
tak's Avatar
tak
Default MIL Codes 12, 13, 25 - Mass Air Flow sensor?
I just bought a 94 Expo and I have a check engine light on and the codes are:
12 Airflow sensor fault.
13 Intake air temp sensor fault.
25 Barometric (BARO) pressure sensor fault.
I also get blue-white smoke intermittently from the exhaust. I suspected HG and I've tested for combustion gas in the radiator and the test was negative.
Then I looked at the spark plugs and they had oil on them both the part that's inside the cylinder and the outside. I also see oil leak around the valve cover gasket onto the exhaust manifold. So I've changed the gasket and the grommets. Then coincidentally the O-ring for the upper coolant hose on the engine block started leaking anti-freeze, and I've ordered the O-ring. So I haven't had a chance to test drive it to see if the smoke is still there or not.
But do you think the engine codes are caused by a dirty air flow sensor? Thank you!
2002Montero
Jun 6, 2004 08:09 PM
1faseclipse
Jun 1, 2004 12:25 PM
1rippinGT
Apr 2, 2004 11:43 AM
ListenersAudio
Feb 22, 2004 05:25 PM
