Misubishi L200 automatic flashing D
Old Apr 17, 2014 | 11:57 AM
amck77's Avatar
Default Misubishi L200 automatic flashing D
Hello, I was hoping I could have some help about a problem we are having with one of our Mitsubishi L200 Warrior trucks.
It is an automatic 4 wheel drive. When drive is selected the "D" comes up on the LCD display in the instrument cluster and starts flashing. The engine management light is on and I believe it is in limp home mode as it stays in one gear, possibly third. All other gear selections work fine.
From what I have read it could be related to the gear box wiring loom, a possible loose connection or break in a cable. I have had a look under the truck and all of the wiring is rapped in conduit and most of it is on the top of the gear box out of sight so I can't really tell if there is any obvious damage.
How would I go about testing each cable to make sure it was not broken?
Old Apr 17, 2014 | 12:41 PM
jkeaton's Avatar
I would get the code read so your not chasing your tail guessing what might be wrong. Use diagnostic tools to your advantage.
Old Apr 18, 2014 | 10:35 AM
amck77's Avatar
Thanks for your reply. I'll look into getting the codes read.
Is there anything I could try in the meantime?
Old May 5, 2014 | 08:15 AM
amck77's Avatar
The truck has been at the garage for nearly a week now and they have so far been unable to find out what the problem is. They haven't gone into specifics with the fault codes, but have said they have spoken with Mitsubishi about the ones they did have. Apparently Mitsubishi have given them some things to try, but they aren't guaranteeing the suggestions will fix anything and the bill is getting larger and larger with no sign of progress or any answers.
Just wondering if anyone can make any suggestions?
Old Sep 8, 2017 | 11:45 PM
Ahmad Firdaus Abu ElIman's Avatar
im from malaysia....unfortunately i hav that problem too...any idea for solution bro???
Winter_C
1st Generation
Jul 17, 2010 04:38 PM
BudP
Mar 15, 2010 08:58 PM
tmd_63
Feb 11, 2008 04:35 AM
jvilleman04
Mar 21, 2006 09:57 AM
