Mitsubishi lancer 1.8 di-d 2014
Old Jul 8, 2022 | 10:09 AM
kennethr's Avatar
Default Mitsubishi lancer 1.8 di-d 2014
I have a problem with the above car The car drives well for a while and then it loses power for a while. It goes like this, when accelerating it sometimes 'stops' around 1900-2000 rpm. With some gears this does not happen with others it does (what graf changes). Then it goes very very slowly to a higher speed or just not. (when pressing the accelerator pedal). once around 2100-2200 it will accelerate faster. This is 10-15 km for a while and then it goes away again. Another remarkable thing, when the car is stationary it has about 600 rpm, but when the clutch is depressed it goes to 900. Occasionally the rpm also 'drops' with clutch depressed. But if the above acceleration problem is 'active' it will always stay at 900. I was thinking maybe a sensor (maybe air mass sensor) or the egr/dpf that needs to be cleaned.
kennethr
Jul 8, 2022 09:30 AM
Axle jack
Feb 22, 2014 02:18 AM
strattam
Aug 26, 2013 12:21 AM
dark_me
Jul 6, 2011 10:39 PM
trace009
May 22, 2008 06:44 PM
