Montero SR - Help Needed
Old Nov 20, 2010 | 08:33 PM
asac55's Avatar
Default Montero SR - Help Needed
Hi all,
I recently bought a 95 Montero SR that had the timing belt jump due to a bad tensioner. Previous owner put a new tensioner on. The engine turned but would not start. It had an exhaust valve bent. Anyway, I took both heads out, sent them to the machine shop, put new valves and seals and reassembled everything back. Getting ready to start and just a "click", no engine turning. Bought a new battery and same thing. Next step was to check the starter. So, I jump wired the starter connectors and the car started. Happy times. At least something, you know.
I unhooked the panel under the dashboard to check the ignition switch. I unhooked the plug and jumped the blue-black and white wires and the engines turn. These two close the circuit for the started only. My assumption is a faulty ignition switch but I can not explain the fact the it crancked when purchased and a month later (yes, it took me a month to put it back together) of just sitting in my garage, it would just not work.
So, I need some advise of what to do next.
Thank you.
Old Nov 21, 2010 | 01:35 PM
asac55's Avatar
Ignition switch....Worn out and was not engaging properly in the Start position. PartsGeek.com carries a lot of OEM parts for these cars. I had great experience working with them. Here is the troubled part:
http://www.partsgeek.com/catalog/199...on_switch.html
mouse406
Feb 23, 2019 07:27 PM
katsat
11
Jan 19, 2009 03:30 PM
Boxcar98
Jul 10, 2008 04:52 PM
fireeatn1
Jun 2, 2007 06:00 PM
myrcgarage
17
Sep 29, 2005 04:39 PM
