my GT is overheating on the motor oil.
Old Jul 11, 2006 | 04:04 AM
enzo_hashmat2006's Avatar
Default my GT is overheating on the motor oil.
I cant seem to figure out why it is overheating on the motor oil. when you start the car the oil temp. just shoots up. and after a while when the water started to warm up, the temperature went down. BUT when i put it in gear the temp. goes back up. only in neutral those the temperature of the oil stay down. help
Old Jul 11, 2006 | 09:59 AM
Default RE: my GT is overheating on the motor oil.
Are you talking about the oil guage on your bezel because im pretty sure thats an oil pressure guage, not an oil temp. guage
Old Jul 11, 2006 | 02:30 PM
yeh thats it. any idea why it shoots up like that
Old Jul 12, 2006 | 03:02 PM
it is the oil pressure gauge, but i cant figure out why it shoots up like that. someone has to know. please help me out my gt is going crazy
Old Jul 12, 2006 | 05:29 PM
hoosierdaddy_87's Avatar
its good that you oil pressure is high = good engine internals also there is no oil temp gauge only engine temp. controled by a sensor on a housing on the engine. 420a?? assuming since GT. check your coolent level and make sure your radiator fans are woking properly. oil pressure gauge has nothing to do with oil temp.
Old Jul 12, 2006 | 05:38 PM
forgot sensors on housing are probblay bad. 2 sensors right beside eachother one is 50 other is 30 at autozone. anything goes wrong with these foreign cars and it costs an arm and a leg to fix it.
First 97 Talon 420a, Second 95 Eclipse 420a, THIRD 95 4g63t GSX AWD 16G TURBO
Old Jul 13, 2006 | 04:15 PM
ORIGINAL: hoosierdaddy_87
WTF are you talking about. The 420a was on the gs and rs eclipses. Im guessing he's talking about a 3000gt.
Its gonna be your pressure relief valve guarenteed. What that is supposed to do is release some pressure when you floor it and then at idle it doesnt do anything. Its probably not opening, thus not releasing the pressure.
Old Jul 14, 2006 | 02:30 PM
Thanks alot Engineer. Where is the valve located so i can replace it? And for everyone else out there my car is a 3000GT
Old Jul 14, 2006 | 02:35 PM
i have no idea on that one man, you might have to get your hands on a manual or try asking in the 300gt section here to see if anyone else knows where it is.
Old Jul 14, 2006 | 02:41 PM
thanks for your help bro.
plomaman
Sep 16, 2012 02:13 PM
LizziVr4
Oct 25, 2008 09:49 PM
Ralliart3000
May 21, 2008 07:13 PM
mitsubu
Oct 3, 2005 08:36 AM
