My sons 1st car is sick
Old Apr 21, 2004 | 12:38 AM
sigfan45's Avatar
Default My sons 1st car is sick
I need your help. My son was driving his 95 eclipse gs when suddenly it started running very rough, by time he got home it would barely run at all.The symptoms are: 1 Rough idle more like it is running out of gas and some slight surging. 2. No power at all on take off nor any while driving 3.wants to die if you leave in gear and siting at light or stop sign. My first thouhgt was the fuel filter or ignition system but would like to have some input from some of yopu guys that may have experienced some of these things yourself and try to save an expensive triop to the repair shop ( as I do not have one I trust here in Dallas) Thanx
Old Apr 21, 2004 | 01:27 AM
Spyderman9803's Avatar
Check for pressure in the fuel lines. Check for any loose vacuum lines. Clean injectors.
Old Apr 21, 2004 | 09:36 AM
madmat's Avatar
how many miles? when was last tuneup?
Old Apr 21, 2004 | 04:57 PM
91eclipse's Avatar
fuel pump....fuel lines.....something to do with the fuel system, thats what im thinking
Old Apr 21, 2004 | 06:06 PM
sigfan45's Avatar
Guys, thank you for your responses,The car has 112,000 miles and had tune up last year but the fuel filter had not been changed. I am going to change it tonight and and see if it helps also he told me today that at highway speeds the rear end gets to rocking side to side on him when he veers to the left slightlyalmost like a very low tire, but only to the left not the rightany Ideas on that issue
Old Apr 22, 2004 | 12:37 PM
get an alignment done....that or needs new tires/rims</P>
Old Apr 23, 2004 | 04:56 PM
91eclipse's Avatar
broken belt in rear tire...my mothers civic did the same thing because she took a turn to sharp and bounced it off a curve.
roundigo
Nov 11, 2016 12:12 PM
radycles
Sep 13, 2008 11:07 AM
vpleonard
Apr 27, 2004 08:47 PM
quicken
Mar 6, 2004 11:37 AM
2fast4u
Sep 6, 2003 06:44 PM
