need help!!!!
i have a 1997 gst. the problem im having is it wont start. i have tested all the sensers and their ok. i get spark on all 4 but no fuel in to the clienders. i have replaced the ecu,coil packs,fuel filter,plugs,wires. the injectors are not pulsing, but the fuel pump comes on.
could the injestor resistor pack be bad. |
RE: need help!!!!
Thats possible or you could have a bad cam position sensor.
RE: need help!!!!
i just found out today that my 97 gst has a 1g motor in it. the can angle is good. that is one of the many things i tested, it has power and is sending signal to the ecm. this all happened when i upgrated the plugs and wires.
RE: need help!!!!
how do i test the cam angle sensor to see if it is bad?
RE: need help!!!!
did you hook the wires into the correct coils? there are 2 coils correct?? on controlls 2 cyl and the other controlls the other 2. If you hooked the wrong cyl into the wrong pack maybe?? I dunno. [&:]
RE: need help!!!!
the wires are hooked up right and the coils been replaced. i have no fuel supply and no speark. i re placer the injector resistor pack and the power transister unit. the car ran fine for about 3 days and than died in a quick chek parking lot. i am really cofused cause i never seen this problem with any car before. question would the cas control spark and fuel?
RE: need help!!!!
and also could a ****ed up turbo cause thes problems
