need help!!!!
Old Apr 30, 2006 | 10:08 PM
xslim69's Avatar
Default need help!!!!
i have a 1997 gst. the problem im having is it wont start. i have tested all the sensers and their ok. i get spark on all 4 but no fuel in to the clienders. i have replaced the ecu,coil packs,fuel filter,plugs,wires. the injectors are not pulsing, but the fuel pump comes on.
could the injestor resistor pack be bad.
Old May 1, 2006 | 10:26 AM
slow420a's Avatar
Default RE: need help!!!!
Thats possible or you could have a bad cam position sensor.
Old May 1, 2006 | 05:45 PM
xslim69's Avatar
i just found out today that my 97 gst has a 1g motor in it. the can angle is good. that is one of the many things i tested, it has power and is sending signal to the ecm. this all happened when i upgrated the plugs and wires.
Old May 6, 2006 | 07:31 PM
xslim69's Avatar
how do i test the cam angle sensor to see if it is bad?
Old May 6, 2006 | 09:24 PM
did you hook the wires into the correct coils? there are 2 coils correct?? on controlls 2 cyl and the other controlls the other 2. If you hooked the wrong cyl into the wrong pack maybe?? I dunno. [&:]
Old May 8, 2006 | 09:05 PM
xslim69's Avatar
the wires are hooked up right and the coils been replaced. i have no fuel supply and no speark. i re placer the injector resistor pack and the power transister unit. the car ran fine for about 3 days and than died in a quick chek parking lot. i am really cofused cause i never seen this problem with any car before. question would the cas control spark and fuel?
Old May 8, 2006 | 09:09 PM
xslim69's Avatar
and also could a ****ed up turbo cause thes problems
91 eclipse gs
1st Generation
Sep 26, 2007 07:03 AM
96eclipsedohc
Feb 8, 2007 09:20 PM
OriginalMirage
Jul 17, 2006 12:53 PM
tuss2oo5
Apr 3, 2006 10:33 PM
Richie03
Dec 12, 2005 11:14 PM
