Need help: (2006) Colt engine knocking/clicking
Old Apr 4, 2015 | 04:04 AM
Tyrel's Avatar
Unhappy Need help: (2006) Colt engine knocking/clicking
Hi everyone!
I have a 2006 Colt CZ3 with an 1.3 petrol engine and the following problem:
When the engine is cold it has a strange knocking / clicking noise, when the rpm falls or under heavy load.
After about 2 minutes the sound goes away, and once the engine heats up it is very very hard to reproduce, if even possible (needs extreme loads to do it).
To have the problem occur again the engine needs to be off for several hours. Because of this, I cannot show it to a mechanic, since by the time I get there, the noise is already gone.
Also the "check engine" light does not lit up, so I'm guessing there are also no error codes to read. (??) The problem has existed for over a year now, but the 2 car mechanics I've asked to check it didn't find anything suspicious. (they haven't heard this clicking)
I've recorded the knocking, you can listen below:
Does anybody have any idea what on earth could be the problem??
Old Apr 4, 2015 | 04:41 AM
Akzle's Avatar
tappets.
Called that, because they tap.
Old Apr 4, 2015 | 06:39 AM
Tyrel's Avatar
How sure are you about that?
Also how big of a problem is it? Should I worry that sometime soon the engine will just blow into my face, or should I simply wait until it gets a little worse so that a mechanic can notice it too?
Old Apr 4, 2015 | 01:11 PM
Akzle's Avatar
not sure at all. I cant diagnose your problems over the internet.
Noisy tappets themselves wont do damage.
If its a failing oil pump, then your car could explode in an horrendous mushroom cloud.
Or not.
Make use of internet Search.
Old Apr 26, 2015 | 06:57 AM
Tyrel's Avatar
Smile Solved
I've finally found a mechanic who could figure out what the heck makes this noise... Once he heard it he was fairly sure that it's not coming from the engine itself, and later found that he was right:
There is a heat shield plate that covers the exhaust pipe behind the engine, which is held in place by 3 bolts that got loosened over the years, probably from the continuous heat-expansion.
No replacement part is required, the plate needs some hammering to make it tighter, after that it can be bolted back in place and the annoying sound is gone... well for a few years more at least, until it gets loose again.
This seems to be quite a common issue (like a series / design issue), so I thought I come back here and tell what was the cause for me, so that others don't have to worry and possibly waste a lot of time trying to get it fixed... at least in my country it's quite hard to find a mechanic who was willing to investigate, and not charge me a fortune for replacing stuff (like the tappets) that weren't even faulty.
Old Apr 26, 2015 | 05:38 PM
Akzle's Avatar
the internets thanks you.
rayo2k10
Dec 6, 2016 05:58 AM
Coltjim
Apr 22, 2015 04:06 PM
Dunas Gorli
Dec 27, 2011 04:01 PM
Speedline
Jun 27, 2011 09:50 AM
Blythetrynity
Sep 8, 2006 09:35 PM
