Need help
Old Apr 1, 2008 | 03:53 AM
Storm's Avatar
Default Need help
So my car has been having some problems lately. Burning oil pretty quick, knocking noise, and tinted blue smoke coming out of the exhaust.
Ive concluded that these would most likely be the lifters, and valve seals. It's still drivable but just not in perfect condition.
Lately its been sputtering at Idle. (like sitting at a traffic light the rpms go down and you can really feel it)
I go in to get a tranny flush n fluids and they tell me that im low 3 quarts of oil ( holy ****). I get it topped off with oil then take my drive home, still sputtering. Almost home and the cel comes on. Reallllly scared me considering i need this car to get myself to school n such.
Any ideas?
98 2g rs
Old Apr 1, 2008 | 06:13 AM
Default RE: Need help
I would start with a compression test if you can rent or buy the tool, or just make one. Here is a great how to on it http://www.geocities.com/dsmgrrrl/FAQs/compression.htm
see what kinda results you get there. But it does sound like the valve stem seals to me. Another possibility is the valve cover gasket. When you are removing the spark plug wires for the compression test, see if there is oil in the holes before you remove the plugs
Old Apr 1, 2008 | 04:52 PM
Storm's Avatar
Im not real good at this, but would it be easy to see if the spark plugs are bad or should i take pictures?
Old Apr 1, 2008 | 07:16 PM
its pretty easy. Just check to make sure the it looks clean. Here is a little guide on them
http://www.theultralightplace.com/sparkplugs.htm
Old Apr 1, 2008 | 10:26 PM
Storm's Avatar
yeahh so i took it over to autozone and used the sensor .
Cylinder 3 misfire detected! ( oh yay!)
Soo i got an NGK Iridium spark plug to put into it, and if that fixes it up ill replace them all.
Old Apr 1, 2008 | 10:53 PM
Kaede.Noir's Avatar
check cables as well
Old Apr 1, 2008 | 10:59 PM
Storm's Avatar
How much would the wires run me?
91 eclipse gs
1st Generation
Sep 26, 2007 07:03 AM
96eclipsedohc
Feb 8, 2007 09:20 PM
OriginalMirage
Jul 17, 2006 12:53 PM
tuss2oo5
Apr 3, 2006 10:33 PM
Richie03
Dec 12, 2005 11:14 PM
