Need Help
Old Aug 30, 2009 | 09:59 PM
WildCard's Avatar
Default Need Help
OK drove 94 3000 gt sl down the road about 9 miles had no issues stopped got out for a bit got back in started down the road and heard a squeal under the hood on drivers side and had a burnt smell and the temp gauge shot to hot in a couple of seconds . does any one have any ideals
Old Aug 30, 2009 | 10:36 PM
1) Check coolant level. If everything is okay, move on.
2) Check over flow bottle. If it's full, go to #3.
3) Do a compression test. If your numbers are odd, then you have a head gasket issue. Then do a wet test to determine if it's the rings, or the head gasket.
4) If everything checks out so far, flush your radiator and change the thermostat.
5) If the issue persists, sell the car.
If you don't know what anything means, google it. You can get your answer far faster yourself than it takes me to read and type it.
Old Aug 30, 2009 | 11:49 PM
WildCard's Avatar
Default Thank you
Could it be the water pump that is causing this as well
Old Aug 31, 2009 | 06:37 PM
Not very likely.
Old Aug 31, 2009 | 07:30 PM
Sebba actually that is likely. If he heard a squeel its pretty good chance that was the belt and the pump may have not been running.
Old Sep 5, 2009 | 11:47 AM
WildCard's Avatar
Default water pump
i found out that it was the water pump locked up tighter then a cookie jar at a fat camp thanks for the help
91 eclipse gs
1st Generation
Sep 26, 2007 07:03 AM
96eclipsedohc
Feb 8, 2007 09:20 PM
OriginalMirage
Jul 17, 2006 12:53 PM
tuss2oo5
Apr 3, 2006 10:33 PM
Richie03
Dec 12, 2005 11:14 PM
