New Here, already have a question.
Old Oct 12, 2011 | 10:26 PM
EuroFanatic's Avatar
Default New Here, already have a question.
Hello everyone, I am new to this forum, I have a question I have had no one able to answer for me. I have a 1996 Eclipse GST, engine has a new air filter, and 3" down-pipe back exhaust. Other than that is completely stock. I replaced every vacuum line in the engine, as well as a MAP sensor that went bad. As far as I can tell, I have no vacuum leaks, and have gone through and tested most every other sensor that can adjust idle...
When the engine is cold, the idle is horrid. Even at WOT the engine will only sit at 1k to 2k and misfire, most of the time will drop down to about 200rpm and then spike back up smooth for a minute. It will continue this until the engine reaches normal operating temp. Then it will run mostly smooth with a slight hiccup.
I took this video tonight in hopes someone has seen this before.
What could cause this? - YouTube
blind2go
Jan 17, 2013 08:14 AM
abo1787
Nov 23, 2008 09:31 PM
first time
Nov 21, 2008 08:22 PM
2007GTEclipse
Sep 23, 2006 08:22 PM
Luv Jones
Sep 9, 2004 08:54 PM
