No Spark and No Start signal.
Old Aug 24, 2010 | 04:35 PM
LancerLot1's Avatar
Angry No Spark and No Start signal.
Hello guys im new at this Forum and I really need your help!
It's a Mitsubishi Lancer GTi 93
The car went well when I bought it, recently it became increasingly difficult to start, later on it just getting worse. The Fuelpump is changed because the other one was bad. After that the spark disappeared for no apparent reason, and gasoline pump is not running(no signal), but the pump is working if you getting power direct to the pump.
We received a tip that it was the ECU, so we left it in for repair and got it repaired, but still the same problem. We have measured currents from the control relay and the ECU and the camshaft sensor, but everything is weird, in some places, it is power when it really should not. And the Control Relay is checked as well is working (after checking with the manual test)
Heard that could be the sensor from the camshaft etc? But we didnt think it was that because after our test, some parts didnt have power or lets say weak, like the ECU had to low power and the control Relay had 12V whole the time which should have lower when the Ignition is on etc.
It's like it doesnt get the start signal when the ignition is turned on?
Some tips on what it could be?
Best Regards!
gjones709
Feb 17, 2011 09:54 PM
3000gt1999
Jan 10, 2007 02:29 AM
dornstar
May 22, 2006 04:58 PM
Kannif0
Oct 25, 2004 11:42 AM
sebastian1023
May 16, 2004 09:09 PM
