not firing on cylinders 2 and 3
Old Jun 19, 2008 | 09:52 PM
macrader1's Avatar
Default not firing on cylinders 2 and 3
i just bought the car tonite. with known problems. its a 1997 mitsubishi eclipse spyder gs-t. the motor has been swapped in the car. not sure exactly what it is maybe someone can figure out by the pics. im only getting spark on cylinders 1 and 4 though. car runs but runs really really rough. anybody have any ideas? i was told to check the coil pack, which i will be replacing tomorrow. other than that any other things that would cause this problem? im also not sure which coil pack to get. i went to autozones website and coulnt find one that looked anything like it.
[IMG]local://upfiles/17348/0A340951EC684C73BF8E4C2F9A8A1A90.jpg[/IMG]
[IMG]local://upfiles/17348/0873F6F2DBAB415B8E3698F4651438DB.jpg[/IMG]
Old Jun 19, 2008 | 09:53 PM
macrader1's Avatar
Default RE: not firing on cylinders 2 and 3
on the plus side i only paid 2400 for the car
Old Jun 20, 2008 | 11:08 PM
If the car runs at all, that means you must be getting some spark, because the car cant run on even 3 cylinders.
CONFIRM that they aren't firing... because that makes no sense.
If its running ****ty, check the timing, check/replace spark plugs and wires.
Old Jun 20, 2008 | 11:25 PM
macrader1's Avatar
cam postion sensor maybe....its not even there. there is however a removable rubber plug where the sensor goes. it seems like the car is going into some kind of weird mode. it will start the first time firing only on cylinders 1 and 4 but if it dies i have to disconnect the battery in order to get it to start back up.
davidsdlck
Dec 22, 2020 06:51 PM
hooelou
Aug 10, 2013 08:53 PM
car&driver
May 9, 2010 10:00 PM
tex1994
Mar 5, 2008 03:22 AM
horine
Apr 13, 2004 02:49 PM
