o2 sensor
Old May 16, 2004 | 04:31 PM
Smoky's Avatar
Default o2 sensor
can anyone tell me which o2 sensor showes a code 11?</P>
Thanks Smoky</P>
Old May 17, 2004 | 11:02 PM
SpyderGS's Avatar
Default o2 sensor
What car are you driving?
Old May 17, 2004 | 11:17 PM
Smoky's Avatar
Default o2 sensor
I guess that would help. 1992 misubishi 3000gt VR4.Sorry about that.<IMG src=smileys/smiley3.gif border="0">
Old May 18, 2004 | 12:34 AM
Mitsu-Tech's Avatar
Default o2 sensor
The quick abc's and 123's about codes just because the o2 sensor throws on a light DOES NOT by any means says the o2 sensor is bad ..the sensor gives the ecm its readings the computer looks at it and figures if ti is in the correct parameter ...so ..you could be dumping too much fuel ..could have a bad catalytic converter could even have an exhaust leak, leaking injector,fouled spark plug etc...as well as many other things ..you need to follow the correct procedures before tossing in an o2 sensor the light may go out for a week and then you may end up saying AH the o2 went bad again ......once again a diagnostic tool would need to be hooked up to the vehicle and look at ALL the readings and make an educated decision from there .</P>
</P>
puwit321
Sep 30, 2014 12:10 PM
Rlopez89
Jul 16, 2013 05:21 PM
batman47
Dec 4, 2011 04:21 PM
sickend
Sep 12, 2006 06:25 AM
5Tizzle
Aug 14, 2006 12:07 AM
