o2 sensor wiring, need help
Old Apr 18, 2005 | 06:42 PM
hambony's Avatar
Default o2 sensor wiring, need help
My buddy at work needs to hookup his upstream o2 sensor (bosch from autozone), the problem is that the previous owner cut out the wiring harness. Any help on how to wire the bosch sensor to the stock wires would be great. His is a 96 base eclipse. Needs it to pass inspection.
thanks in advance
Old Apr 18, 2005 | 07:22 PM
DSMTalonAWD51's Avatar
Default RE: o2 sensor wiring, need help
wire it up the same way the one you take off is wired. if you already took it off then you have to obtain an electrical schematic from the shop manual for the car, either by buying one or asking the dealer nicely if you can look at it for a minute. i dont think anyone is going to have that info off hand online.
Old Apr 18, 2005 | 11:24 PM
nate5023's Avatar
Buy extensions for it thats what my friend had to do.
Old Apr 19, 2005 | 01:10 PM
hambony's Avatar
That's what I thought. Thanks for the info, I will pass it along.
Old Apr 22, 2005 | 12:10 AM
dnau's Avatar
I had to replace the O2 sensor on my 95 tsi with that autozone bosch special. Problem was, the wiring harness didn't fit the stock connector. So I took the existing o2 sensor and chopped the wires on the old one and chopped the wires on the new one and spliced them together. Total hack job. The stock connector wiring was white, white, black, grey. The new bosch was black, black, white, blue. So i took an educated guess and put black to white, black to white, white to black, and blue to grey. Took it to advance autoparts to have it the codes pulled and it no longer trips the lead O2 sensor code.
silverslug88
Dec 23, 2013 04:43 PM
BruceWayne
Apr 8, 2010 10:48 AM
sickend
Sep 12, 2006 06:25 AM
96tsi
Aug 13, 2006 07:36 PM
