OBD II Codes
Old Mar 15, 2006 | 05:45 PM
Gsteclipse22's Avatar
Default OBD II Codes
Hey all I have a quick question. I ran my buddies scanner through my 99 eclipse and two codes popped up. 1494 and 1495, if anyone knows what these codes mean or if there's a website that could help me I'd greatly appreciate it.
Old Mar 15, 2006 | 06:44 PM
NESpeed's Avatar
Default RE: OBD II Codes
P1494 Evaporative Emission Ventalation Switch or Mechanical Fault , not sure on the 1495.
Old May 6, 2008 | 11:50 AM
eclipseGS98's Avatar
I have the P1494 code coming up as well. I searched and found it could be a leak. I was thinking about hooking the smoke machine up to my car. Would this help? Any suggestions, please.
Old May 6, 2008 | 12:27 PM
Don't bring back old threads. Make another but include your search results in it.
P1494 Leak Detection Pump Switch or Mechanical Fault
To answer your question, I am guessing this is a vacume leak of some kind. Perhaps a blockage or leak in the EGR some place. That is all I can gather.
Old May 6, 2008 | 04:27 PM
Well after I fill it, you can smell strong gas smell. I replaced the filler neck because that was leaking before and appeared to be the only part leaking. I can only smell it, don't spot any puddles. Tomorrow I'll hook the smoke machine up to it and see how it goes.
Old May 6, 2008 | 08:05 PM
You could just try and remove the battery for 1 min to reset the ECU, and see if the code stays off. Sometimes it can be a freak and just throw it.
Hungry Horace
Aug 13, 2013 04:02 PM
Miles2Go
Apr 11, 2012 08:40 AM
Stryker
Sep 16, 2007 08:36 PM
Dusty Eclipse
Jul 15, 2007 12:43 AM
davesrave
Dec 21, 2004 04:27 PM
