Oil Leak
Old Oct 14, 2005 | 06:30 PM
Limey's Avatar
Default Oil Leak
1997 Eclipse 2.0 Turbo. Have an oil leak, leaving a small amount of oil on the ground near front drivers side. I have cleaned the front of the engine, cannot get to the back. Oil appears to be coming from between the block & exhaust manifold....is this possible & if so what is the cause. Not blowing any colored smoke from tail pipe. If not possible, any suggestions where the leak is [8D].
Old Oct 16, 2005 | 09:28 AM
wicked_outlander's Avatar
Default RE: Oil Leak
ORIGINAL: Limey
you need to replace gasket, also check your manifold fittings.
Old Oct 17, 2005 | 12:17 AM
DSMTalonAWD51's Avatar
could be head gasket or jus the valve cover gasket
ccernst
Jan 14, 2011 08:38 AM
TheRock0720
Nov 12, 2010 12:30 PM
Mitsibitchi
Jan 31, 2005 02:47 PM
darkman0127
Jul 9, 2004 06:32 PM
OZ2003
Nov 26, 2003 10:38 PM
