overheating help.........2 questions
Old Jun 10, 2008 | 11:15 AM
97mitsu_rs's Avatar
Default overheating help.........2 questions
i was sitting at a red light and i started to smell anti freeze i look down and my car i runnin rele hotttt so i start to pull off the road and when i give it gas it starts to cool down relativly quickly...so i experiment with it and it does it at every time i stop. can you guys help me out?
and 1 more thing when should i get my next tune up im at 89k miles i dnt have a car manual thats why im askin?
thanks
Old Jun 10, 2008 | 12:45 PM
Default RE: overheating help.........2 questions
How are your coolant levels?
Old Jun 10, 2008 | 03:50 PM
Kaede.Noir's Avatar
**** POST PROBLEMS!
That worked...
Old Jun 10, 2008 | 03:52 PM
I hate when that happens...
Old Jun 10, 2008 | 03:53 PM
Kaede.Noir's Avatar
im trying to give feedback cuz i went thru this... and i cant!!
Old Jun 10, 2008 | 05:21 PM
97mitsu_rs's Avatar
coolant levels are good...the thermostat is new and its not a cheap one either...i jst had hte oil changed but i dnt think that would matter.... some one suggested the water pump might be bad but idk
Old Jun 10, 2008 | 05:23 PM
You have either a leak or a bubble in the coolant lines.
Remove the cap and let the car idle a little, then check the level
Old Jun 10, 2008 | 05:29 PM
silvercoupe97's Avatar
ORIGINAL: 97mitsu_rs
ORIGINAL: Sebba
Judging by the comment above, I have to agree with you Sebz. Chances are, someone forgot to relieve the motor of trapped air.
I recommend this route before a new water pump.
Old Jun 10, 2008 | 05:32 PM
Glad I have your approval
Old Jun 10, 2008 | 06:00 PM
Kaede.Noir's Avatar
yeah... also with the cap off you can see if water circulates, if not, radiator leak
