Passenger rear drum has play! How to fix for DIY
Old May 11, 2013 | 12:06 AM
JackLancer03's Avatar
Thumbs down Passenger rear drum has play! How to fix for DIY
Hello there fellow Mitsu's
Last week I had a flat tire, in the process of removing the lugs with a lug wrench I snapped the bolt out of the wheel hub, the nuts were on that tight. So after an expensive tow, torching off the remaining bolt and buying a new rim, I decided it was a good time to do my brakes.
I completed doing the rear shoes and when I put the drum back into place it goes in fine, solid. But when I put the tire back on it moves the drum and thus results in some play in the rum, even with the lugs on tight. Any ideas what could be the cause of the problem? I'm going to look at it tomorrow and see if I can figure it out. But right now, the lugs go on fine, and the drum has play. When I drive it sounds like a flat tire, but it's the drum scraping the outer housing of where the brakes are. I have full braking, but this knocking sound is worrying me, which I imagine is the sound of it rotating loosely, hitting something else.
The drums are very rusty and corroded on the exterior(Many Newfoundland winters and salt in the air), I don't believe the previous owner took much care too it. Any ideas as to what the problem is/how I can solve it? Any help is appreciated.
Old May 11, 2013 | 01:02 PM
mxmikie's Avatar
sounds like a bad wheel bearing what does your manual say ?????
byebye_sti
Apr 19, 2010 05:34 PM
byebye_sti
Apr 19, 2010 05:33 PM
Jkook89
Aug 22, 2008 03:48 PM
knupxfon
Mar 16, 2006 03:46 AM
theduke1959
Jan 16, 2005 11:41 AM
